Motor Selection
Motor Selection
Motor Selection
Greetings
Is there any formula to Calculate size of Electric Motor (HP RPM)????
Application:- To drive a structure which runs on steel wheel and steel track... there are total 6 wheels in that frame.
Flow of power will be
Motor>gear Box> Chain Drive >Gear > Wheel
Ind
RE: Motor Selection
No sir
actually we manufacture such machine.
Can you give better detail for this as we need to select a motor to drive this structure(which is carrying some weight)
we use magnesium bush for wheel
RE: Motor Selection
Calculate the force required to accelerate this cart. Maximum weight and quickest acceleration would be the numbers to use for this. It's a simple formula - F=ma
The above force will translate through the pulleys and gearbox to a torque and rpm.
Use the torque and rpm to pick the motor.
Don't forget to account for the losses.
The steps are simple but knowing what numbers to use can be tricky.
RE: Motor Selection
thanx for ur help
So F=ma
and Torque = F X r
R will be radius of wheel or what???
and HP = torque X rpm
but what about friction???
RE: Motor Selection
Just be aware, itsmoked's Tq/HP formula was truncated, likey just for the sake of discussion.
It's really
 T = 5252 x HP
               rpm
Then use your math skills to convert when you know parts of it from Lionel's information.
(naughty naughty Keith, you know you shouldn't toy with the Mechos like that). winky smile
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
RE: Motor Selection
You will need a certain force just to overcome the friction. There will be a force required to overcome the friction both when stopped and when accelerating. Add it to the calculated F=ma force.
Dont' forget to account for the speed changes and efficiency of the different drivetrain parts (gearboxes and belt or chain drives).
RE: Motor Selection
thanks everyone
one last thing radius used in torque formula will be radius of wheel???
RE: Motor Selection
Yes, the radius at the wheel would give the torque at the axle.
