Looking for a compressor with a threaded inlet.
Hello all,
Im looking for a compressor/pump that will solve my current problem. I need a compressor that has a threaded inlet so that I can pull a gas from one vessel to another and pressurize the second vessel with that same gas. All the compressors I have found just pull the air for the surroundings. Does anyone have any suggestions?
RE: Looking for a compressor with a threaded inlet.
What gas are you compressing?
What's the pressure in the first tank?
What's the pressure in the second tank?
How much gas are you moving? I.e. flowrate, or some indication of it.
Mike Halloran
Pembroke Pines, FL, USA
I'm not understanding why you couldn't eliminate the first tank, and draw from the atmosphere with a two-stage compressor with an interstage cooler.
Mike Halloran
