Shear Factor is for mild carbon steel in direct shear?
Does anyone know what the shear factor is for mild carbon steel in direct shear?
I need a dowel pin to shear and release two parts at a given load. The load is applied perpendicular to the dowel pin axis.
I want to calculate the pin diameter that will shear at this load. I know the UTS is 75 ksi. I just need the shear factor so I can calculate the shear strength. Shear Strength = Shear Factor x U.T.S.
Thanks.
CJ
Thanks.
CJ
RE: Shear Factor is for mild carbon steel in direct shear?
htt
