Stroke Volume in pump
Hi Guys,
I am designing a diaphragm pump and I want to calculate stroke volume of a diaphragm pump regarding pressure,I need to have stroke volume for each pressure to calculate pump flow rates. Under diaphragm(rectangular shape)I have a pressure fluid and this fluid pushes the diaphragm up, I have amount of this pressure(under diaphragm). Actually I could not find any formula about that. Anybody knows some references for stroke volume in diaphragm pump regarding pressure?
RE: Stroke Volume in pump
Do you have the performance curve of the peristaltic pump (pump speed and flow rate vs. pressure)? That would perhaps allow you to calculate the effective stroke volume of the diaphragm as the volume displaced by the peristaltic pump is equivalent to the volume which dispalces the diaphragm, unless you have a bypass somewhere between peristaltic pump and diaphragm.
We have a available Diaphragm pump design having a discharge capacity of 2L/hr and I want to scale it to 36g/hr(new diaphragm pump).
What parameters should i first calculate?
Please help me?
what determines the opening pressure of the suction side valve and pressure side valve(non return valve)?
Thanks in advance,
Rishi
Please start a new question.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
