NX8.0.0 journal problems
We are experiencing issues with running journals in NX8.0.0 (on Windows 7 SP1, 64 bit). We get errors related to library loading when running the journal from either the command line, or from within an open NX session.
The journal in question is a very simple "File>Open" procedure, and it works perfectly fine in NX7.5.3.
When run from the command line, the NX8 error is:
Error loading libraries needed to run a journal.
Caught unexpected error: 3600001: No message for HRESULT 0x80004001
When run from within an already-running NX8 session, an error box titled "Hit OK to continue" pops up, saying "Invalid attempt to load library". I've attached a screenshot of the error box.
Has anyone seen similar problems with journaling in NX8? Any idea how to fix it?
RE: NX8.0.0 journal problems
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks!
"...to replay a .NET journal, the .NET Framework 4 must be installed.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Especially since by default, up-to-date (ie with all standard MS updates applied) Win7 SP1 workstations will not have .NET 4 loaded... So I expect many users who use journals might run into this problem.
