Aluminum Corrosion
Aluminum Corrosion
The aluminum siding and door framing on my trailer is experiencing severe pitting from what I suspect is galvanic corrosion. I can also detect a small current to ground from the trailer even with the power disconnected, which I assume is from galvanic cell potential betwen the aluminum and the steel frame being in contact. Am I on the right track and what might be a possible solution?
I was told grounding the trailer frame will drain off the current and might reduce the corrosive action. Does this make sense?
RE: Aluminum Corrosion
