Elastomer closed cell insulation for heat conservation
Peers,
Can anyone pls advise on the closed cell elastomer insulation for heat conservation below 120deg C? It is industry practice to use mineral/rock wool, cellular glass for heat conservation, but not really sure about the limitation of elastomeric material as HC insulation on gas process piping. Since the temp range > 90 -150deg C is quite critical to avoid CUI, I expect there are some previous industry experience on using this material.
Cheers
Cheers
RE: Elastomer closed cell insulation for heat conservation
Sometimes wooden blocks as supporting when You need a fixed support.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
