Discontinued ASTM spec and drawings
Do the ASME drawing specifications make any provisions for obsolete ASTM or other specifications that have been replaced by newer specifications? For example, an older drawing calls out a material in accordance with ASTM A570. The A570 spec has been replaced by A1011. Would the drawing have to be updated? Thanks!
RE: Discontinued ASTM spec and drawings
There are orders for MIL-45208A and MIL-9858 still being let by the primes. Probably because the design was proven using those Standards and it would take a re-qualification to update the design.
The only ASTM specs that are considered usable are the current ones. We won't certify to old ones.
ASME though requires that Code rev to be stated. So if you want material to 81ed we would do everything (testing, properties, chem, marking) to that edition.
Don't get me started on obsolete MIL specs. There are some that we no-quote to because the spec says that we must have written approval and there is no longer a source. This doesn't stop some of our competitors but I am not going to caught in that trap.
Plymouth Tube
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
