Basic Heat Transfer Question
Let me start by saying that I have not taken heat transfer yet. My question seems like it should be very basic, but I just don't know which equation to use.
I have a heat source that is 500 degrees F. If I have a heat shield at some distance away from the heat source, with air separating the two. How hot will the heat shield be?
What properties do I need to know in order to solve? Basically, I'm looking for an equation to apply to this problem. Thanks in advance!
RE: Basic Heat Transfer Question
TTFN
Chinese prisoner wins Nobel Peace Prize
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
TTFN
Here's one thread to get you started: thread391-305369: Heat Transfer / thermal radiation.
Patricia Lougheed
Cheaper than spending hours working out equations which will probably not give you the right answer anyway!!
Don't forget that ambient temperature, humidity and wind will play a BIG role....
