Green vs Black book
Green vs Black book
Do the new building codes, like IBC 06/09 require the design per LRFD method? I haven't done a lot of steel design in the last three years as I was doing concrete work full time so I am out of touch with the changes. Am I required to do a beam design per ASD and LRFD of the black book? I am doing some simple roof beams and columns and am wondering if I can just use the Green book.
I am confused.
I am confused.
RE: Green vs Black book
I found this thread useful.
I won't tell on you. But watch out for reduced shear stud capacities in the Black book.
1. ASD or LRFD - most all codes in the US (and elsewhere I believe) allow both.
2. Black book (which has both ASD and LRFD in it) OR the Green Book? - That depends upon the code that has been adopted in the jurisdiction of the project. If you are in the US, the code is typically the IBC. The year of the IBC which is in effect for the city/county/etc. that you are in would dictate which AISC specification you have to design under. Look in IBC chapter 35 for a list of references and look up AISC. It should list the applicable AISC spec version.
