Applying Boundary condition to a node in an input file
Hi Guys,
How do you apply a boundary condition to a specific node in an Abaqus input file? When an input file is generated a set is created for each node. Here is an example
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
*_PickedSet5, 1, 1, 0.1
*_PickedSet5, 2, 2, 0.2
*_PickedSet5, 3, 3, 0.01
*_PickedSet5, 4, 4
*_PickedSet5, 5, 5
*_PickedSet5, 6, 6
How can I apply a displacement to a node without creating a set? So instead of _PickedSet5 how can I change this to just a node number. The following does not work
*Boundary
1, 1, 1, 0.1
1, 2, 2, 0.2
1, 3, 3, 0.01
Any help would be much appreciated
*Boundary
*_PickedSet5, 4, 4
*_PickedSet5, 5, 5
*_PickedSet5, 6, 6
*Boundary
1, 1, 1, 0.1
1, 2, 2, 0.2
1, 3, 3, 0.01
RE: Applying Boundary condition to a node in an input file
%%You must first create a node set:
*Nset, nset=MyBCs, instance = Part-1-1
8,17,32
%%MyBCs is the name of the set and Part-1-1 is the name of my part %%in the assembly. Next you apply the boundary condition type to the %%node set.
*Boundary
MyBCs, ENCASTRE
*Boundary
Assembly.Instance1.1,1,1,0.1
I'm not 100% sure on this but I know it works for other keywords like *initial conditions so its worth a shot.
I got it working in the end, using a hyperworks mesh input file. I think Mech Ireland is right, you need to reference an instance each time you reference a node for a BC.
