modelling a 3Dspring
Hi everyone,
I would like to create a beam (beam1) bearing on two simple supports (ok) and then added a perpendicular beam named beam2 at mid span on beam1 (ok).
My problem is that I would like to create a spring in every direction, 3D, using CBUSH (is that the best way ?) but I don't succeed. I create a element between beam1 and beam2, defined the cbush properties but I quikly figure out that the analysis is not correct...
Any ideas to help me?
Thanks a lot
Maxime
PS I am using patran2010
