Fit table?
Fit table?
Does solidworks (i have 2008 currently, but will get 2012 soon) have a fit table (e.g. D20 h7 - the lower and upper limit value for it) that i could include in a drawing?
Preferrably via built-in swx method or do i have to write a macro?
RE: Fit table?
http:/
RE: Fit table?
http://h
RE: Fit table?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
RE: Fit table?
I'd ideally want to have a table (general table, like BOM) near the head of the drawing that displays all fits and provides tolerances for them (as is per DIN standard).
Is there anything available that can summarize the surface finish (e.g. entire model 6.3, except for the marked areas that are 0.8 etc)?
RE: Fit table?
As for the finish, make you own set of notes with the CommonNotes macro from http:/
RE: Fit table?
RE: Fit table?
