Topology bus no longer working
I use the topology bus infrequently but the option is useful when you wish to alter the number of defining sections within a surface that is defined from a file (.ibl) but for some reason the option no longer appears to work under wildfire 3 date code M230, I'm not sure if this has been moved to a floating module and if and which one (NX?). I have tried altering my config.pro and amending the file and asking the topology bus to update but the file amendment is not seen. Any ides would be appreciated
RE: Topology bus no longer working
