SVC Design
SVC Design
Does anybody know how to decide the number of branches in a SVC?
The question is to design a SVC using TSC and TCR for smooth control say around -100 to 400 mvar connected to a 345 kv bus via a transformer of suitable size. Kindly help! I really dont know where and how to start!
Also, how to design filter for the same and perform loss calculations?
Thanks!
Thanks!
RE: SVC Design
aka - TLA = Three Letter Acronym
RE: SVC Design
RE: SVC Design
Hint. Do you have a target PF envelope? (TPFE) If all else fails you can use a WAG solution.
Bill
"Why not the best?"
Jimmy Carter
RE: SVC Design
The Req. control for voltage is 0.95 pu-1.05 pu..
Also filters for 5th and 7th harmonics are needed. Smooth control over -150 inductive to 400 capacitive with maximum switching of 150 mvar possible.
I know how to achieve smooth but there are multiple techniques.
Does anybody know a definite way of doing this?
RE: SVC Design
RE: SVC Design
RE: SVC Design
RE: SVC Design
Bill
"Why not the best?"
Jimmy Carter
RE: SVC Design
The place where im stuck is the filter and whether the capacitor branches are acceptable.
RE: SVC Design
1.Defining load profile
2.Harmonic analysis of the load
3.Harmonic Analysis of TCR part
ABB and some others have fixed harmonic portions according to application.
RE: SVC Design
It is a big project and nothing you shall do without having any experience at all. Ask ABB, they have done hundreds and hundreds SVCs.
Gunnar Englund
www.gke.org
RE: SVC Design
