Rotating view using Mac mouse
Hello, I just finished installing SW2011 SP3 on my iMac at home and running it through Parallels 6 so I can work away from the office.  I can't seem to get the Mighty Mouse to rotate parts or assemblies when I click and drag as I can on my Windows PC at work.  The ball works great for zooming but that's all it'll do.  I have a sinking feeling that SW does not work well with a Mighty Mouse and I'm going to have to put in something else.  Any help is appreciated.  Thanks!
Mechanical Engineer
Field Forensics, Inc.
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Rotating view using Mac mouse
You may have to resort to using the SW Rotate and Roll tools if the mouse software does not enable that function.
I've used one of those on a Mac with SW and I can tell you that it is possible! I'm not in front of my Mac at the moment so can't tell you how I ended up doing it, but I did it.
Check in your settings somewhere - maybe program specific settings?
Sorry I can't be more direct haha!
I run SW using Bootcamp.  I just use a standard mouse, and it works fine.  I'd like to find me a 3Dconnexion to plug into it yet too... I use one all day at work, and I miss it when modeling at home :(  LOL!
Derrick Hochgesang
Specials Project Engineer
