2nd opinion on dimensioning scheme
Does anyone see anything inherently wrong or ambiguous with the attached drawing per ASME Y14.5M-1994 (and/or Y14.5-2009)? I've been staring at my drawing of a part with similar features and have been battling in my head first and foremost with the Ø1.25 feature located using a positional tolerance versus locating the conical taper feature (datum B) using run out.
In use a cylindrical shaft will fit over the Ø5 feature until it bottoms out against the feature located from the virtual sharp by the .25 linear dimension and then secured using an adhesive. This shaft will slide within a tube that has a female 100 degree conical taper. The conical taper will limit the translation within the tube. This is why I've selected datum features A and B as shown. There will also be an accompanying assembly drawing where the OD of the fitted shaft will be datum feature A' and the conical feature will be datum feature B'. I want the similar features to serve as the datum features in both the component and assembly drawings.
RE: 2nd opinion on dimensioning scheme
Frank
Big oops on my part. The dimension to the "bottom" of the profiled surface should be from the vertex of the conical taper. The magnitude would then be .875 & not .925.
This wasn't intended to be a complete drawing. I tried to provide enough detail as possible to address my main question.
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
The issue is not can it do it, but should it do it, that is determined by functional requirements we have not been given. One of the changes in the 2009 standard it to allow specification of datums that can actually restrain more degrees of freedom but are referenced to do less, obviously to mirror some intended functional requirement.
Frank
I agree with your statement in general, but in the absence of any indication of datum precedence violation (u, v, or w in the FCF), I would read this print as it is, not necessarily as it should or could be. As it is, I still believe the profile callout is overconstrained.
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Thanks for your feedback. I agreed with Powerhound that I over constrained the datum structure since Datum A would already arrest all but the translation along the long axis. When I sent the original email I threw in the 2009 standard reference as I was considering using a customized FCF whereby datum feature B would be the secondary datum (A being primary) and arrest this last degree of freedom (there is no need to clock, thus no tertiary datum to constrain rotation about the long axis). After Powerhound's response I reconsidered leaving datum feature B as my primary without the need for a secondary.
However, now I'm back to looking at a customized FCF since datum feature B really isn't big enough to physically arrest all the motions. Datum feature A does a better job since (in my actual part its longer).
I'm not sure what other functional requirements beyond what I supplied in the OP would help elicit some better feedback.
If I understand the functionality correctly, the assembled/adhered tube abutts the face which is normal to datum feature A, which makes it a better secondary datum feature than the conical feature. Don't get me wrong, I love cones, but there is a significant issue using them as datum features in '94. In '94, you get the same constraints as for a cylindrical FOS, but you also get a point location/locking down the translation along the datum axis. The issue is that the point is rather difficult to reproduce with even the slightest variation on the taper draft, and therefore less than effective as a datum point (i.e. origin of measurement).
Also, the conical surface isn't located in a useful way; a surface profile is the preferred and more replicable way to control a conical surface, eliminating the need for a runout control in most cases.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
The tolerance zone for a profile control extends the length and width of a surface. However, if an edge, corner or another tangent surface begins, the profile tolerance zone ends. The leader line of the OP profile control is directed to the arc R.100, that means the profile tolerance zone covers the arc surface up to the tangent point at each end of the arc. Pls note as soon as the surface changes geometry, the profile tolerance zone ends. This is the default condition for profile.
There are three other ways to extend the coverage of a profile control:
• The between symbol
• The all-around symbol
• The all-over symbol
For the OP, the between symbol could be your candidate, you need clearly specify the two tangent points.
SeasonLee
I agree, but... an issue arises with finding the tangency point between two surfaces in practice. As a result, I tend to use the between symbol perhaps more frequently than absolutely necessary to eliminate ambiguity.
SeasonLee
Does it matter that the flat won't be accessible after assembly when the cylinder shaft is abutted against the flat? This is why I was trying to make the tapered cone the secondary datum as it would be present both before and after assembly. Also the flat surface doesn't have to be tightly controlled since I only care that it stops the cylinder after contacting one point on the surface. Any thoughts? Is this where I compromise on choosing a functional datum feature over a convenient one (at least with the component before assembly)?
Also why does there seem to be an aversion to run out being used to control the location and form of the conical surface? For me the inspection set up is more flexible that way.
I do think I'll add the in between notation for the profiled surfaces. I'm sold on the fact that it would remove ambiguity.
Checking profile controls on a cone isn't a big deal really, it just takes a bit more setup. Once you have the datum simulated (i.e. part fixtured) and the axis established, you set up an indicator stand with parallel bars to run parallel to the nominal conical face (at a basic angle and offset from the axis), then slide the indicator along the bars as you rotate the part. I've seen setups doing this before. Alternately, incline the datum simulator which establishes the axis at half the basic conical included angle wrt the surface plate. Don't let surface profiles or cones intimidate you, they're both massively useful once you get the hang of them.
If you're thinking about using the cone as a datum feature, make it the primary feature then and get the axis & point all in one. Just keep in mind that the datum point may be hard to establish repeatably.
Frank
If so, my question is: what is the location of runout tolerance zone relative to specified datum axis? Let's say we are talking about circular runout. Aren't two circles defining the tolerance zone coaxial with datum axis and therefore tied in radial direction?
Thanks for you caught the point : "Just keep in mind that the datum point may be hard to establish repeatably". To specify a back face as a secondary datum will make the datum point repeatedly and easier for inspection.
SeasonLee
That's just a fancy way of saying size. When we think of location, we are usually implying a feature-of-size location, which boils down to an axis or centerplane's location. In that respect, runout certainly controls location.
John-Paul Belanger
Geometric Learning Systems
Thanks for the reigning in Jim,
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Powerhound, sorry if I seemed harsh; not intended. I'm also trying to fire off reponses quickly as I prepare for some upcoming training.
