LPG Storage Tank
LPG Storage Tank
I'm looking for a storage tank of 100-500 gal. capacity to store liquefied hydrocarbons mix with pressure of 330-350 psig at 115F. This pressure is above a commonly used tanks with 250 psig limit. Any suggestions where to find a tank or info about it? Thanks.
RE: LPG Storage Tank
h
IMHO, most LPG storage tanks commercially available are built for a MAWP of 250 psig (propane/ammonia) or 300 psig (propylene)
You can always get a vessel designed to whatever pressure you specify.
Specifically, what MAWP do you desire ?
http://www.hansontank.com/propanetanks.html
You should also be aware of this:
http:
340 psig at 115F is the calculated pressure of my hydrocarbon stuff. Too bad the propylene cylinders will not fit.
First, I need a small, like under 1,000L, cylinder for development stage, then a larger one, like 4-8K litres. I hope to find ready avalable cylinders as making a special one(s) is not economically feasible.
This still sounds a little strange - how the heck are you going to transport such a wild product? Most highway LPG transports are the same pressure - 250 Psig.
