Array of points. Connection points between curves
Hi everybody,
I'm still working on my CATIA script to create a body from some points coordinates I have in an Excel file. I found great information about scripts to perform this task, so it is going pretty well. However I still have a problem.
Here is the deal. I have curves which share some 'conection' points, as this vertices are belonging to 3 or 4 curves in some intersections. If I write the Excel file with all the points for each curve I guess it will result in some cases in to 3 or 4 'different' points at the same coordinates. How can I fix this problem?
My idea was to create a ConnectionPoints array where all this vertices are loaded. Then another matrix where each row is the curve I consider, and the columns are the beginning and ending conection point index. Something like this, considering I just have 4 vertices to build up a pyramid.
[1 2; 2 4; 2 3; 1 3; 3 4; 1 4]
Then, when I create the splines, first I add the start point, then I just read all the points but the extremes from the Excel file, and finally I add the end point. Please, find below the code. So, when I run it, it gives me an "Type Mismatch" error in the command
Spline(iSplineId).AddPoint ConnectionPoint(iStartPointId)
I was expectig it to add the connection point with index iStartPointId in the spline, but it doesnt. I think it is because of ConnectionPoint(...) type. But I don't have any other idea about how to fix this problem without creating this ConnectionPoint array...
Any help or advice is welcome. Thanks in advance...
L3munoz.
Sub BuildingModel()
    Dim PtDoc As Object
    Dim PtPart As Object
    Dim PtHybridBody As Object
    Dim myPtHybridBody As Object
    Dim myPtSheet As Object
    Set PtDoc = GetCATIAPartDocument
    Set PtPart = PtDoc.Part
    Set PtHybridBody = PtPart.HybridBodies
    Set myPtHybridBody = PtHybridBody.Add
    myPtHybridBody.Name = "Train Geometry"
    Set myPtSheet = GetExcelFile
    Dim iLinea As Integer
    Dim iValide As Integer
    Dim X As Double
    Dim Y As Double
    Dim Z As Double
    Dim ExtremePoints() As Integer
    Set ExtremePoints() = GeometryInfo
    Dim ConnectionPoint() As Object
    Dim Point As Object
    Dim Spline() As Object
    Dim iPointId As Integer
    Dim iSplineId As Integer
    Dim iStartPointId As Integer
    Dim iEndPointId As Integer
    iLinea = 1
    iValide = 0
    iPointId = 1
    iSplineId = 1
    While iValide<> ciEnd
        AnalyzeCell myPtSheet, iLinea, X, Y, Z, iValide
        iLinea = iLinea + 1
        If (iValide = 1) Then
            While iValide <> ciEndConnectionPoints
                iLinea = iLinea + 1
                ReDim ConnectionPoint(1 to iPointId) As Object
                Set ConnectionPoint(iPointId) = PtPart.HybridShapeFactory.AddNewPointCoord(X, Y, Z)
                myPtHybridBody.AppendHybridShape ConnectionPoint(iPointId)
                iPointId = iPointId + 1
            Wend
        End If
        If (iValide = 2) Then
            ReDim Spline(1 to iSplineId) As Object
            Set Spline(iSplineId) = PtPart.HybridShapeFactory.AddNewSpline
            Spline(iSplineId).SetSplineType 0
            Spline(iSplineId).SetClosing 0
            iStartPointId = ExtremePoints(iSplineId,1)
            iEndPointId = ExtremePoints(iSplineId,2)
            While iValide <> ciEndCurve
                iLinea = iLinea + 1
                If (iValide = 0) Then
                    Set Point = PtPart.HybridShapeFactory.AddNewPointCoord(X, Y, Z)
                    myPtHybridBody.AppendHybridShape Point
                    Spline(iSplineId).AddPoint Point
                End If
            Wend
            Spline(iSplineId).AddPoint ConnectionPoint(iEndPointId)
            myPtHybridBody.AppendHybridShape Spline(iSplineId)
            iSplineId = iSplineId + 1
        End If
        PtPart.Update
    Wend
End Sub
