How to find out the NX Assembly file size in Teamcenter.
I want to find out the NX assembly size in Teamcenter.Is it possible??...
RE: How to find out the NX Assembly file size in Teamcenter.
In teamcenter, right click on the file of interest and choose 'named references'. In the dialog that pops up there will be a 'size' column, it will list the file size.
Dear Cowski,
Thanks for your information.
But i need to find out the NX assembly size having more than 800 components.
Is there any possibility to find out the Entire assembly size in Teamcenter??
Backup the assembly file to disk and check the size of the folder.
May not be rocket science, but it does give a faster result than adding up the individual file sizes in TC.
Most likely you could write a SQL file to extract that information.
Ben Loosli
Thank you very much Looslib for your timely response
