Problem with nodal solution contour plot in ANSYS
Hi all,
I have never had this problem before when using ANSYS Classic but for this particular 3D model, when I plot the nodal contour plots, the elemental plot seems to be overlayed on the results (or vice versa). I want the contour plot to just show the volumes or areas even. If I go and play with the edge options, I can remove all the lines but then I have no indicator of where the boundaries of each area/volume is.
Does anyone know how this issue could be solved? Just for a bit more information, it's a 3D model and I have created a working plane though the middle of the model and here I create a cut plane.
Thanks in advance for any help!
