Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
scottyj1 (Mechanical)
22 Sep 11 16:10
I have searched around and can not find any information on regulations for or against hanging fire extinguishers inside of a fire extinguisher wall cabinet.
I have a few different types.
The ones that have a twist handle and the door is opened to access the F/E is not so much an issue.
The ones that have the plastic/glass breakaway seem to me to create an issue.  Once the breakaway is well...broken away the opening is large enough to grab the F/E which is sitting freely in the box.  The ones that are mounted on a bracket inside the box seem to create a bit more effort to pull out.
I would like to be able to present something definitive to my supervisor who seems to have a pet-pieve on hanging these things or drop the issue all together.
Scotty
cdafd (Specifier/Regulator)
22 Sep 11 18:46
How many extinguishers total do you have???
So does your supervisor want the cabinets???
And if so which one???
The other thing to look for is Ada compliant cabinets
http://cliffsfire.com/html/fire_extinguisher_cabinets.html
Helpful Member!  JerSPK (Mechanical)
22 Sep 11 20:58
I'm interested if there is a specific standard reference for this myself.  Every cabinet we have ever provided we just rest the extinguisher on the bottom of the cabinet.  The vast majority of existing cabinets I've seen do the same, but a small percentage have had the extinguishers hanging on hooks inside the cabinet.
.....looking in NFPA 10 (2010) it says the following:
6.1.3.4* Portable fire extinguishers other than wheeled extinguishers shall be installed using any of the following means:
(1) Securely on a hanger intended for the extinguisher
(2) In the bracket supplied by the extinguisher manufacturer
(3) In a listed bracket approved for such purpose
(4) In cabinets or wall recesses
Based on that I would interpret that they don't need to have a hook when inside a cabinet.
chicopee (Mechanical)
23 Sep 11 16:02
The use of steel cabinets is to deter vandalism or malicious  mischief to the portable fire extinguishers.  These steel cabinets would have a breakable glass front. An attached rod or similar tool  with a chain would be fastened to the cabinets.
Close Box
Join Eng-Tips® Today!
Join Us             Close
