References with long path names
I'm working on a network with a deep file structure and long-ish directory names, so that when I insert a reference file into one of my Mathcad documents the displayed path is almost always wider than the page.  Since it doesn't wrap, when I print the document the end of the path (with the most important part:  the reference file name) ends up on a separate page at the end of the document.
Is there a way to either make the path wrap, display only a relative path, or truncate the displayed path?  I have tried using a relative path to the reference, but Mathcad still displays the full path.
RE: References with long path names
I forgot to mention that I'm using Mathcad 7 Standard.
Map a drive to a point high enough to contain all the files, but deep enough to make the path short enough.
davidbeach:
Thanks, that's a great idea.  But I'd like a solution that works for anybody who opens the file, if there is one.
