Hydrostatic testing
Hydrostatic testing
Hydrostatic testing
Do you have Airgas, BOC, or some other welding gas supplier that is local to you?  Here, I take it to the local welding supplier.  161 bar is not insane pressure in the world of gas cylinders.
RE: Hydrostatic testing
Check with a local boiler/pressure vessel manufacturer or qualified repair shop. They should be equipped to handle hydrostatic testing.
Thanks people, I did try BOC and they did not have a clue.
I have found a diving place that looks good.
http://www.patersonsafety.co.uk/
lifornia, we exchange the bottles at the supplier, when due is a blessing; they take care of the certification and with the exchange we get a fresh tested/certified tank. any gas tank.
may be your supplier can do the same!
