Lofting in assemblies
Is it possible to create a loft between two sketches in an assembly to create what would look like a twisted piece of steel plate, ie a piece of 10x100mm flat streched between two faces which are not parallel,
RE: Lofting in assemblies
Give me your e-mail address and I will send you an example of one that a drafter created where I work.
Bradley
