PATRAN - How to use Field
Hi all,
How do you create a non-spatial field in patran?
I am trying to simulate crushing of a cylinder between one deformable plate and one rigid plate.
The deformable plate needs to move at a rate of 1mm/sec downwards towards the top of the cylinder.
I have tried using the "velocity" tool on patran to move the plate but NASTRAN wigs out when I do that.
I cannot use "displacement" because it doesn't specify the time step.
Any tips/comments is very much appreciated.
Thanks!
RE: PATRAN - How to use Field
How to calcualte L-Angle plate bending stress and shear stress
