Extending Range of an IR remote control
Hi
I am having probs with some neighbors who insist on hanging 200W RMS loudspeakers outside of their apartment opposite mine while they listen to music in their back yard!! I have have devised a method of controlling their hifi using an IR multifunction remote and simple telescope to switch off the equipment over 150Yard range. I did have direct line of view, however they have now moved the hifi and I can no longer control it.
I would be interested to know anybodies thoughts on the feasibility of using a 960nm laser module to transmit the same signal which I could then aim at one of their internal walls directly opposite the hifi. I'm assuming the wavelenth is 960nm and also assuming that the specular reflection would be picked up the the IR receiver. My only concern is that a 1mW laser wouldn't have the umphhh to do the job. Any thoughts would be appreciated.
RE: Extending Range of an IR remote control
TTFN
