Is there anyone knows EPA SWMM??
First of all, I'm practicing hydraulics for quite a few months now. Only recently I had a hard time doing calculations manually or in an excel spreadsheet. I need to calculate or check the HGL or EGL of my storm water system that uses circular pipes and box culverts in a very large network.(i.e. 4km in length with branches that ranges from 500 meter to 1 km in about 22 sq.-km drainage area; yes in SI units)
They say EPA SWMM is capable of calculating the HGL of a large network, section by section, from upstream to downstream outlet. Is that true?
I tried going thru the tutorial and help guide but I couldn't find that it actually does what it says.
When I tried to profile it, I can't see the HGL.
Can anyone help me out?
Thanks in advance.
RE: Is there anyone knows EPA SWMM??
Click on "profile plot"
Then select start node and end node (then click on find path) then "ok".
The run simulation.
Map and animation tool.
IMO, EPA SWMM us a good free software.
EPA SWMM is not always the friendliest outputs for reviewers, but it's a very powerful and very comprehensive piece of software.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Okay thanks for the response. However, it seems I'm gonna need to read again the tutorial. I can't understand how the Map animator works and also the choices in Themes (subcatchments,Nodes,links and how it relates to the layout) and time period. I can't identify the "head" (I suppose that's the HGL)in the animator once I play it..it doesn't do anything.
Theme
Subcatchment: Area
Nodes: Head? Is this correct?
Links: Depth or what?
Time Period
Date?
Time of Day?
Elapsed Time?
I think the time is with regards to the duration I input in the time series....am I correct?
I don't know how to call it but the input choices...I'm worried there might be something wrong or I didn't chose the right one for the simulation to run correctly and give me correct results. But it does say the run was successful. I guess I have to trust that, don't you think?
I guess so, because some of my colleagues are saying the same thing...it's a very good hydraulic software. But none of them have the time to explain and train me comprehensively how to use it. We are all busy right now. So I have to teach myself how to use it by reading the tutorial. The only word I remember in the end was HAPPY SWMMING!
DrainageR,
Most tutorial starts with complexity.
To explain SWMM5, I start with the simplest network possible. Two tanks connected with one pipe, and one outfall.
Try to run it and then try to understand it, and try to manipulate it. Thanks
[TITLE]
[OPTIONS]
FLOW_UNITS           CFS
INFILTRATION         HORTON
FLOW_ROUTING         DYNWAVE
START_DATE           09/26/2011
START_TIME           00:00:00
REPORT_START_DATE    09/26/2011
REPORT_START_TIME    00:00:00
END_DATE             09/27/2011
END_TIME             06:00:00
SWEEP_START          01/01
SWEEP_END            12/31
DRY_DAYS             0
REPORT_STEP          00:15:00
WET_STEP             00:05:00
DRY_STEP             01:00:00
ROUTING_STEP         0:00:30
ALLOW_PONDING        NO
INERTIAL_DAMPING     PARTIAL
VARIABLE_STEP        0.75
LENGTHENING_STEP     0
MIN_SURFAREA         0
NORMAL_FLOW_LIMITED  BOTH
SKIP_STEADY_STATE    NO
FORCE_MAIN_EQUATION  H-W
LINK_OFFSETS         DEPTH
MIN_SLOPE            0
[EVAPORATION]
;;Type       Parameters
CONSTANT     0.0
DRY_ONLY     NO
[OUTFALLS]
;;               Invert     Outfall    Stage/Table      Tide
;;Name           Elev.      Type       Time Series      Gate
3                100        FREE                        NO
[STORAGE]
;;               Invert   Max.     Init.    Storage    Curve                      Ponded   Evap.
;;Name           Elev.    Depth    Depth    Curve      Params                     Area     Frac.    Infiltration Parameters
1                100      10       10       FUNCTIONAL 10000    0        0        0        0
2                100      10       0        FUNCTIONAL 10000    0        0        0        0
[CONDUITS]
;;               Inlet            Outlet                      Manning    Inlet      Outlet     Init.      Max.
;;Name           Node             Node             Length     N          Offset     Offset     Flow       Flow
1                1                2                100        0.01       0          0          0          0
2                2                3                100        0.01       3          3          0          0
[XSECTIONS]
;;Link           Shape        Geom1            Geom2      Geom3      Geom4      Barrels
1                CIRCULAR     1                0          0          0          1
2                CIRCULAR     1                0          0          0          1
[LOSSES]
;;Link           Inlet      Outlet     Average    Flap Gate
[INFLOWS]
;;                                                 Param    Units    Scale    Baseline Baseline
;;Node           Parameter        Time Series      Type     Factor   Factor   Value    Pattern
1                FLOW             ""               FLOW     1.0      1.0      0
[REPORT]
INPUT      NO
CONTROLS   NO
SUBCATCHMENTS ALL
NODES ALL
LINKS ALL
[TAGS]
[MAP]
DIMENSIONS 0.000 0.000 10000.000 10000.000
Units      None
[COORDINATES]
;;Node           X-Coord            Y-Coord
3                777.672            5534.351
1                -1312.023          7099.237
2                777.672            7099.237
[VERTICES]
;;Link           X-Coord            Y-Coord
