Resolution Precision Accuracy of a ruler
Hi
For testing purposes I have to measure the change of a distance (about 50mm). Easy. I would like to use a steel ruler instead of a dial gauge with rod for it, but the standard I am working to says that the instrument should have a resolution of 0.5mm and a precision of 0.1mm. I can get a ruler with 0.5mm increments, but I am struggeling to tell what the precision of my instrument (the ruler) is. And then there is accuracy, but I guess I have that sorted if I have the ruler calibrated...
I understand what precision from the definition point of view (Precision is how close the measured values are to each other)but am unable to apply this to my ruler problem. How can an instrument have a precision of 0.1mm when the resolution is 0.5mm?
Hope somebody understands my problem...
RE: Resolution Precision Accuracy of a ruler
does the standard define its terms ?
But maybe it means they want the measured result with one decimal place???
Yes, that how I first understood it, but how can you get a precision of 0.1mm with a 0.5mm resolution? If you take the precision as 1/2 the smallest unit the best I can achive is 0.25mm. But according to the it seems possible to get a precision of 0.1mm with a 0.5mm resolution.
There are no further definitions given in the standard.
David
So, if you measure the same 'gold standard' (or maybe this time platinum iridium in a climate controlled environment standard) say 10 times, are all 10 readings within .1 of each other?
You may not be able to verify the 'precision' of your instrument using the instrument itself.
I guess the point in your situation is you don't want a part that is measured initially and 'rounded up' to the next .5mm increment, to be measured again and 'rounded down' to the lower .5mm increment.
(Or something like that, you want to ask the guy sat opposite me, he loves to go on a rant bemoaning peoples lack of understanding of the difference between accuracy and precision in a metrology context)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
It defines "resolution" as the minimum change in input for which there will be a change in output, in this case, 0.5 mm.
It seems possible to me that the precision can be smaller than the resolution.
This textbook is about instrumental measurements and instrument performance, I am not certain these definitions have the same meaning for something like a steel scale.
Mike
TTFN
Chinese prisoner wins Nobel Peace Prize
So either the standard is wrong
or I need an instrument that has a resolution of 0.5mm and a precision of 0.1mm. Still not sure how that is going to work since the resolution does not allow me (or the dial) to read in 0.1mm steps, therefore my results would spread over more than 0.1mm. Anybody can come up with an intruments that fulfills the above requirements (or should I go down the line that there is a typo in the standard...?)
Obviously it would be foolish to measure something to 52.3mm but I at least know if something comes out at 52.5mm it is between 52.3 and 52.7mm (except I'm not standing in the metrology lab so it's going to be wrong)
Designer of machine tools - user of modified screws
IRstuff
Yes, I agree, but why would a standard state a resolution of 0.5mm
and a precision of 0.1mm???
Tuckabag/Ninja
If the standard would ask for an accuracy of 0.1mm I would go with you, but accuracy and presicion are 2 different things.
Guess I have to find out from whoever wrote the standard. Wish me luck!
Standards are like specs; even in the umpteenth rev, errors and omissions can still be found, if you look hard enough.
We can also play the game of what do the numbers and their precisions mean in the standard. Does the standard call out ±0.1mm, or ±0.10mm? If the former, then your steel rule might still work out, since your measurement uncertainty is ±0.25mm, and your repeatability ought to be about ±0.125mm, which rounds down to ±0.1mm if only 1 decimal place is used. While this approach is a bit cheesy, it's not an implausible position to take.
TTFN
Mike McCann
MMC Engineering
But have you thought about the "carbon-based-ruler-interface" here? What is scribed on the ruler is almost irrelevent compared to how the reader is actually looking at the "ruler" and determining exactly where he is reading: Any parallax? Is he looking dead-on perpendicular to the surfaces? How is he determining what he is reading: If I stick a ruler down a hole, but the hole is drilled out, then is my ruler tiny enough to go partially "into" the 118 degree tip of the hole?
Is this a thickness where you are laying the ruler across a rounded edge or a an irregular edge? Or a machined square corner? Do you have a sliding gage or "stop" that you move to the surface/edge and then read?
And yes, I consider using stops for better readability.
