Solid Bodies BOM
Solid Bodies BOM
I have modeled a part made up of two solid bodies. I have entered said part into an assembly with another part. Now when I make a drawing of the assembly the BOM only recognizes the solid body as a single part. Is there a way that I can have the BOM recognize this as two different parts rather than inserting them as two different parts and assembling them?
Thanks!
Thanks!
RE: Solid Bodies BOM
Multi-bodies are not separate parts; they exist to assist in creating a part.
http://
RMB on the Solid Bodies folder in the Feature Manager, select Save Bodies and use the Create Assembly option
Agree with CorBlimeyLimey!
A BODY is a fractional part, which is not qualified as a part. If you like, you can create a cut-list for your multi-body part. Not sure if that serves your purpose.
Generally speaking, if you do what you say, your assembly and BOM shall be fine.
Best regards,
Alex
