Toolbar: Synchronous Modeling
Hi
I have a few days using NX7.5 and in application modeling I try to use radial toolbar synchonous modeling with MB3 but it doesn´t appear.
Some one of you know how can I get this toolbar with MB3?
Attached image with current radial toolbar.
Thanks for your tips
Tom
Tom
NX 7.5.4.4
RE: Toolbar: Synchronous Modeling
If you want a radial popup toolbar with synchronous commands (and who doesn't?), I suggest you customize one of the radial popup toolbars (the ones that pop up when you hold down Shift + Control + LMB|MMB|RMB. If you use a spaceball, assign the Shift + Control key combo to a button and you can just press 1 spaceball button alogn with 1 mouse button and get the popup menu you want.
To edit the radial popups, right click on a toolbar and choose Customize. On the toolbars tab, scroll down and make sure Radial 1, Radial 2, and Radial 3 are checked. Drag and drop commands (button icons) to the toolbars as you see fit.
Thanks a lot for your comment. Using Shift + Control + LMB|MMB|RMB is the better way to work in 3D with popup toolbars.
By other hand, the next week the company will buy SpaceNavigator (and we will see).
Best regards
Tom
NX 7.5.4.4
