How to check different layer's strain in ABAQUS (composite)
Hi guys!
Just wondering how could you check different layer's strain? I tried some settings but can only check the first ply's strain, which is the facing...
but i also need to chech the core or layer 2 3 4 etc...
anyone know how to do that?
thx
---Mike
thx
---Mike
RE: How to check different layer's strain in ABAQUS (composite)
You can create the section view from the default coordinate system's planes or by your own defined normal. You can then probe internal nodes. Is this what you mean?
I created a sanwich plate and just want to see each layer's strain~ but I can just check 'layer-1''s strain~ that is my question~
but the restult still showing layer-1
I think I am very close to the truth but just need one more
Page 22. That should do it. Good luck.
For others to solve this problem quicker, I would add:
result---section point--- plies --- top,middle,bottom
