Trying to make a stripper
I am trying to extrude a rectangle up to a part, the rectangle is larger than the part, I just want the surface of the part cut into the stripper. It is a pretty complex part, and no option seems to work. I get either 'the body does not fully terminate the extrusion', or 'the end face cannot terminate the extruded feature'. How do I make a part that is bigger than the area I want to extrude to?
RE: Trying to make a stripper
Dan
www.eltronresearch.com
Dan's Blog
Extend the surfaces at boundaries to cover your extrusion.
Attach your file here if you can't figure it out.
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
