EN 13445 Tube Sheet Design
My question is regarding the "uniform thickness for a minimum length adjacent to the tubesheet" requirement specified in 13.4.6.2 and 13.4.6.3 for integral tubesheets.
My calculation ends up stating that I need a minimum channel length adjacent to the tubesheet of 498mm for the channel thickness of 109mm and inside diameter of 1054mm. Does this imply that no nozzle can be located on the channel within that distance from the tubesheet?
RE: EN 13445 Tube Sheet Design
A properly reinforced opening may be in that region without impairing the ability of the shell to resist the bending of the tubesheet, as the reinforcement reconstitutes the thickness.
The reference to 9.7.2.1 is for openings close to a discontinuity: this affects the reinforcement calculation, not the wall thickness, and I assume it should be used whenever that condition is present, even if not referenced by other code parts.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
