recording concrete temperatures
Contractor is getting ready to pour about 5,000 sq ft of 12 - 18 inch thick, 4,000 psi reinforced spillway slab. The liklihood is that cold temperatures may be an issue and the CM is looking for some sort of temperature gauge that can measure and automatically log the temperature of the concrete during the cure. Any recommendations?
RE: recording concrete temperatures
Dik
Dik
cvg...you might consider a maturity meter...will do the same.
