wrench clearances
wrench clearances
Machinery's Handbook (25th) has tables of clearances for wrench openings up to 1-5/8". Can anyone direct me to info on wrench clearances for larger sizes?
RE: wrench clearances
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
But, since those clearances are good for wrench sizes up to 1-5/8, and the difficulties of fabricating a "wrench-turnable" part bigger than 1-5/8 are no harder, just the 1-5/8 tolerances.
Looking at the problem the other way, do you need to design a space to "attach" and "turn" a wrench for a 2-1/2 nut? If so, get the wrench you will use, and measure the length and max diameter of the wrench head. Using a socket wrench or impact wrench to turn the part? Do the same thing - but check your design to make sure there is room to attach and remove and operate the impact wrench and its adapter.
ht
Lyle
