Parallel coding of Abaqus subroutines
Hi, I am using Abaqus vuel and vumat subroutines. It seemed that the Abaqus explicit solver is much slower than LS-Dyna explicit, I wonder if this is true or I didnot set the time step control in Abaqus correctly?
To speed up the simulation, I want put some parallel coding in the Abaqus subroutines. In LS-Dyna coding, I simply need to include 'mpif.h' below the subroutines, then I can use the MPI functions such as MPI_ALLREDUCE, but in Abaqus, " include 'mpif.h' " didnot work. Does anyone have the experience of parallel coding in Abaqus subroutines? Can you give me any clue of this?
Thanks a lot.
RE: Parallel coding of Abaqus subroutines
