Interesting Aerofoil Platforms
Morning Brainics,
I have an issue and I'm hoping one of you smart people can help me out.
I have a turbine blade to produce, this turbine has awful platforms, (coloured red).
I can cut the aerofoil, But the platforms are causing me a headache.
Please can somebody point me in the right direction.
I'm using version 7.5
Cheers
Alan
Cheers
Alan
RE: Interesting Aerofoil Platforms
You have two good curves when looking in the z-axis but the shape in the x-axis not what you want?
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Thanks for your response,
I think my first post is mis-leading,
This is the model I recieved from the customer, (some features have been removed).
I want to manufacture the platforms, (RED).
I know the platforms are messy, but thats what the customer requests.
Cheers
Alan
I posted a few days ago.
I really am stuffed when it comes to manufacturing these platforms.
Ideally i would like to use the aerofoil as the drive surface & cut the platform spiral style.
I can cut the aerofoil in this fashion, but when the tool reaches the platform, the stepover is to large, due to the drive surface/check surface intersection curves generated.
Which manufacturing cycle do you think would work
What drive condition should I use
Etc....
Thanks in advance
Alan
Somebody must know how to do this.
I really am stuffed on this issue, any input would be great.
Yours going bold swiftly.
Alan
If you could post a couple views of the blade, I can look at it tonight at home. I'm at work (no internet here at work, only Blackberry). I've done several types of platforms myself on single blades.
Bill
Thanks for your post,
Theres a parasolid file attached to this thread.
would that be ok?
Alan
Sorry but I can only view images but I think that might be enough.
I have attached a couple of screen grabs,
my status:-
I have been machining single blades for 4 years.
I machine blades on a 5 axis Starrag machine.
The software I use can only handle revolved platform surfaces.
The platform surfaces on this blade are chaotic surfaces!
I know how I would like to cut the platforms,
I have average knowledge of NX 7.5, but I can't get nx to cut these 2 platforms.
Ideally I would like to drive around the aerofoil in a spiral cutting the platform outside to inside.
Please reply
Alan
Bill
Bill
Thanks for sticking with me.
I'm doing ok as you will see from the attached jpeg.
But:-
I'm having issues with the 'tool axis' selection drop down box.
I have no idea which to select, I've tried various options, but all options seem to shoot the tool into space.
Any input would be great.
Alan
I set the tool axis to revolve around a line, then tip the tool about 30 degs.
Thanks for your help Bill,(wmalan).
You deserve the stars.
Alan
Glad to help!
Bill
