If statement using a vector
Hi Guys, I need to use an if statement and one of the inputs is a vector and I cannot get it to work.
I have an equation like this
Z:=if(C*D > min(A,B),min(A,B),C*D)
Where C and D are both vectors.
The message I get is that they need to be scalar quantities. I have tried converting A & B into vectors and using a basic program but no luck.
Any help would be appreciated.
RE: If statement using a vector
I did discover that one of my values that I thought was a vector was actually a scalar number.I have a min function above comparing a fixed number and a vector and I had assumed (idiot) that it would have pulled down the vector.
I have tried multiplying the vector and scalar (creating another variable) previous to this function and using this in the if function but still no luck.
I have included a copy of my equation. Your help is greatly appreciated.
Peter
You could use max(reinadd.n ⋅Heightrein.n) and compare this with max(A1.n ,A2.n). This will compare the highest value of the product (112.25 mm²) with the higher of A1.n and A2.n. Is this what you want?
