Selection Mask Array
I was wondering how to have the NX Journal selection mask array select all curves including lines and splines.  So far If I use
.Type = UFConstants.UF_line_type
or
.Type =  UFConstants.UF_spline_type
I can filter for either a line or a spline.  But I would like to filter for all curves.
This is the selection mask portion of my code:
     Dim selectionMask_array(1) As Selection.MaskTriple
        With selectionMask_array(0)
        .Type = 1
            .Subtype = 0
            .SolidBodySubtype = 0
        End With
RE: Selection Mask Array
Just use additional masks one for each of the curve type you wish to include.  For example for lines and splines to be both selectable the code would be:
selectionMask_array(0).Type = UFConstants.UF_line_type
selectionMask_array(0).Subtype = 0
selectionMask_array(0).SolidBodySubtype = 0
selectionMask_array(1).Type = UFConstants.UF_spline_type
selectionMask_array(1).Subtype = 0
selectionMask_array(1).SolidBodySubtype = 0
Frank Swinkels
