Engineerng Refresher
I'm sure some others out there have had this same issue so I figured I would ask here first...
I have been out of school for about 8 years now and I'm finding that I am forgetting more and more of what I used to know. The only thing that stays fresh in my head is statics and machine design because I use them frequently. I would like to get back up to speed on calculus, system dynamics, controls, and heat transfer but I don't want to go back and read my text books all over again.
Can anyone out there recommend a good resource (book, website, etc.) to refresh my brain? I would prefer something that has examples and practice problems.
RE: Engineerng Refresher
ocw.mit.edu
So why bother???
Cooling Techniques for Electronic equipment by Steinberg
Vibration Analysis for Electronic Equipment by Steinberg
Calculus by Kline
Mechanical Engineering Referance Manual by Lindeburg
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Failing that, the original textbooks are what I fall back on.
SNORGY.
good luck!
-pmover
"Mechanical Engineering Reference Manual for the PE Exam" Lindeberg
Brian
www.espcomposites.com
So, I would recommend that you get the books , do some of the problems and then for a good a source of everyday problems go to the various engineering forums and start answering some of the problems and read some of the answers.
Then, you can use the books as a resource when needed and stay sharp.
