Wire Ropes and turnbuckles meets ASTM?
Hi!
I´m having a litte confusion with the following:
-If I´m going to supply a vessel, it must meet ASTM in materiales (so for ASME too)
but....If I´m going to supply a vessel that contains auxiliary equipment as wire ropes and turnbuckles...these auxiliary stuff should not meet ASTM or ASME specs should it? I mean, in order to talk to my user, there is any document that I can support myself to tell that thsese auxiliary stuff should not meet ASME/ASTM but Federal Specification.
What do you think?
RE: Wire Ropes and turnbuckles meets ASTM?
Saver2008,
I think they should meet
ASTM F1145-92, for turnbuckles.  You can check with the wire rope tech board for any other standards you should meet. http://www.wireropetechnicalboard.org/
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
If their failure could compromise safety then you need to work to a recognized standard.  That is what they are for.
Plymouth Tube
Dear Berkshire, thanks that´s it.
Thank you so much!!!
