Adding\copying to the PDMWorks vault from outside the vault using API
First off I've just started dabbling in SWX & PDM API, so please excuse my ignorance.  I need to change an existing macro that currently creates a file on a network path(a simple text file that we use for manufacturing).  I now need it to add this same file to our PDMWorks vault.  I can get it to add the file, but it shows up as a local file.  I need it to add it to the vault.  I tried using IEdmFolder5::CopyFile but that needs a folder ID for the source folder, but my source isn't in PDM.  I also tried IEdmFolder5::AddFile but the example in the API help only adds it to the root folder of the vault.  I'm not sure what direction to go here.  Any ideas?
