Facet body & Surfaces NX6
Friends
Actually I am working with a stl file, let me describe the steps.
1.- Import stl file in "NX facet body"
2.- I project curves onto stl body to know the dimensions of it and later create a solid body in second plane. (hidding and showing stl body)
3.- using insert>surface>rapid surfacing I select some regions of the facet body generating independent surfaces from this body.
Then I have a solid body in a plane and a stl file in other.
The question is, Can I copy the new surfaces generated onto stl body on a new solid body?
Thanks for your comments
Tom
Tom
RE: Facet body & Surfaces NX6
Tom
In short, your links don't work; please rename and reupload the files.
Thanks for the tip, I send the file
Tom
