B31.8 Corrosion Allowance
Does B31.8 require corosion allowance when calculating min wall thickness?
RE: B31.8 Corrosion Allowance
not that i'm aware - at least CA is not mentioned in B31.8 for determining min wall thickness.
hope this helps.
-pmover
B31.8 does not require a corrosion allowance.  You may include extra thickness over and above the reqired minimum at your discretion.  In fact, no code that I know of requires a corrosion allowance at all.
We are more connected to everyone in the world than we've ever been before, except to the person sitting next to us.  Lisa Gansky
