Three punch average --> hardness measurement
Hi
Can someone please describe what the meaning of three punch average is? This is in connection with Hardness measurements.
Thanks!
RE: Three punch average --> hardness measurement
Typically, particularly with API tubular specifications, a single Rockwell hardness value is defined as the average of three individual Rockwell readings taken in the same vacinity.  That is, to obtian a Rockwell hardness value, you would take three "punches", or readings, in the same area and take the aritmatic average of those readings to obtain your hardness value.
rp
