Trifle sponge depositor
hi I have been tasked with looking at a way to place sponge circles onto a conveyor belt , info below .
Sponge 60mm dia x 9mm thick ,harder than cake sponge but not as hard as a biscuit also tends to stick together a little bit if stacked . Mechanism needs to be speed regulated to conveyor via control system so only works when product called for etc.
Delivery rate 80 per minute per conveyor, sponge needs to land on conveyor in single file spaced at 90mm centers .Sponge arrives in cardboard boxes in stacks 500mm high , it is the hope of the customer that 1 person can feed 4 conveyors .
Really just looking for guidance to the best way to do this , thought of having them in long stacks say 1.5m high above a rotary disc type depositor but cant think of an easy way to keep the weight of the stack from causing sticking issues .Any help greatly received .
Cheers Tim
Cheers Tim
RE: Trifle sponge depositor
Perhaps you have the option to do this using robotics. You should investigate of the "delta" or "spider" robots from Adept Technology, ABB, Fanuc. SCARA-type robots may also be an option. You would need to employ "conveyor tracking" to synchronize the place point on the moving conveyor belt.
Then you'd have to be clever on how to present the sponges to the robot.
In case you don't recognize it, you've got quite a task in front of you.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
If you want some help, email me and we can help you out with some suggestions.
There are a lot of options and a lot of questions.
Charlie
www.facsco.com
