RS Logix Emulate
RS Logix Emulate
How to do the Emulate (rs emulate)read the pc com port (#1),when the rslogix emulate is running at the same time.
RE: RS Logix Emulate
It's all described in the Help file and configured through the Settings drop-down menu.
I know that ascii (ascii ARD) instructions but first we need communicate with another drive (AB df1 not work in my case).
pT. I'm try to read data from pic16f877a. This is not a ALLEN Bradley device. So that drivers dont work.
You must implement a protocol in the microcontroller that the SLC-500 understands. With the Emulate 500 controller, your options are ASCII or DF1 Full Duplex.
Returning to the real world, I think I found a solution using a economical solution. factory talk studio has a more user-friendly platform or even the scada software. And thanks for your spent time with my "doubt".
In any case, good luck with your project.
