what type of rubber is more common for demin water pipes
Hi!
Please let me know, the more common type of rubber suitable for boiler feedwater (demineralized water)? and how about thickness?
thank you
thank you
RE: what type of rubber is more common for demin water pipes
before determining materials, the fluid properties and operating parameters are stated/determined. all that is known is demin H2O and most people reading this do not have osmosis or telepathic capabilities.
more data is needed before a reasonable response can be provided.
good luck!
-pmover
operating pressure is 3.5 bar
operating temperature is 39 deg C
Pipe sizes are 10,12,14 inch.
Thank you
