Flexible couplings in water piping
We are replacing a 12 inch water main in a city street with cement lined ductile iron pipe. We will be stopping about 30 feet away from a highway overpass where the main is hung below the bridge.
The plan calls for finding the existing main, cutting it and coupling to it with a solid sleeve. Then we'll hang a gate valve and start the replacement pipe.
There was a break at this location several years ago. The repair has served well with no further problems.
Should we put in a flexible coupling near the abutment?
RE: Flexible couplings in water piping
